comment différencié une BVA 46rh d’une 42re
Ayant un probleme de boite auto (la 3eme patine ,3.200t pour passer)
Je cherche comment différencié une 46rh d’une 42re sur un grand cherokee 5.2l de 1995
patton27- NEWBIE
- Nombre de messages : 3
Re: comment différencié une BVA 46rh d’une 42re
Hello
Si tu lis l english
Trouve via google
the main difference between the 42RE and the 46RH is the RE & RH symbols that follow. The 4 stands for 4 speed...the 2, I believe stands for the size of the unit.
the "RE" signifies that the tranny is electronically controlled..hence the "E" at the end.
the "RH" signifies that the tranny is hydraulically controlled..hence the "H" at the end.
ALL ZJs from late 1993-1998, with the 4.0L straight 6 engine, had the 42RE Transmission in them. Any V8 from 1993-1998 had the 44RE or 45RE, to the best of my knowledge. RAMS usually have the 46RH in them.
If you have the 42RE, look for another one, or a rebuilt unit. swapping a 46RH is damn near impossible (unless you want to change the wiring and computers in your vehicle too...PITA) Hope this helps.
Si tu lis pas l english....je te traduirais
Si tu lis l english
Trouve via google
Thank you
the problem is what is not and I do not know what model is itIt has no plate with the reference
patton27- NEWBIE
It depends on your engine and production year
Look upward....it s written
Regards
Regards
re
how how !!!
j'ai perdu mon sucwe!!
tournicoti tournicoton!!!!!!!!!!!!!
- Nombre de messages : 1981
» Boite 42RE - Problème de passage 2 vers 3
» Procédure réglage bande boite auto 42RE
» Comment ca s'enleve ca
» comment savoir sur YJ
» comment ajusté tranmission
