35 €
MA JEEP CJ7 DE 1982
MA JEEP CJ7 DE 1982 Empty MA JEEP CJ7 DE 1982
Message  laurentpierre Sam 26 Juil 2014 - 19:05
PRESENTATION DE MA JEEP CJ7 DE 1982 QUE JE BICHONNE DEPUIS 25ANS
MA JEEP CJ7 DE 1982 20140614
VUE D EN HAUT
MA JEEP CJ7 DE 1982 20140712
VUE DE COTE
MA JEEP CJ7 DE 1982 20140612
DETAIL PHARE AVEC LONGUE PORTEE EN DESSOUS A LA PLACE DES CLIGNOTANTS
MA JEEP CJ7 DE 1982 20140713
GRILLE AVEC VENTILATEUR ELECTRIQUE SUPPLEMENTAIRE DECLANCHE PAR SONDE THERMO CONTACT
MA JEEP CJ7 DE 1982 20140714
MODIFICATION CLIGNOTANT+VEILLEUSE EN ROND POUR FAIRE PLUS JOLI !
MA JEEP CJ7 DE 1982 20140715
AMORTISSEUR DE DIRECTION AVEC RETOUR AU CENTRE DE MARQUE TOUGH DOG
MA JEEP CJ7 DE 1982 20140718
MA JEEP CJ7 DE 1982 20140719
DETAIL PARE CHOC INOX ARRIERE EN TUBE INOX DE FABRICATION ARTISANALE + ECHAPPEMENT REMUS DE WRANGLER
MA JEEP CJ7 DE 1982 20140720
TRAPPE A GAZ OIL MODIFIEE SUR LE COTE DE TYPE AVIA POUR FAIRE JOLI !
MA JEEP CJ7 DE 1982 20140721
ATTELAGE SPECIALE POUR REMORQUE JEEP DE TYPE BANTAM
MA JEEP CJ7 DE 1982 20140722
TABLEAU DE BORD EN INOX AVEC AUTORADIO RETRO
MA JEEP CJ7 DE 1982 20140723
VOLANT EN BOIS RIVET LECARRA
MA JEEP CJ7 DE 1982 20140724
HAUT PARLEUR ARRIERE INTEGRE + PRISE 12V ETANCHE MARINE + ECLAIRAGE ARRIERE
MA JEEP CJ7 DE 1982 20140725
VUE DE DESSUS DU MOTEUR 6 CYLINDRES TURBO DIESEL
MA JEEP CJ7 DE 1982 20140613
SUPPORT MOTEUR AVANT GAUCHE VUE DE DESSUS
MA JEEP CJ7 DE 1982 20140726
SUPPORT MOTEUR AVANT GAUCHE VUE DE DESSOUS
MA JEEP CJ7 DE 1982 20140727
SUPPORT MOTEUR AVANT DROIT VUE DE DESSOUS
MA JEEP CJ7 DE 1982 20140729
DETAIL ENSEMBLE MASTERVAC+MAITRE CYLINDRE+ REPARTITEUR DANS LE COMPARTEMENT MOTEUR COMME SUR LE WRANGLER+COLONNE DE DIRECTION RENFORCEE
MA JEEP CJ7 DE 1982 20140731
VERIN HYDRAULIQUE POUR OUVRIR LE CAPOT + LAMPE DU COMPARTIMENT MOTEUR AVEC CONTACT AU MERCURE
MA JEEP CJ7 DE 1982 20140730
ENTRETOISE EN ALU ENTRE BOITE DE VITESSE ET CLOCHE D EMBRAYAGE
MA JEEP CJ7 DE 1982 20140732
laurentpierre
laurentpierre
Nombre de messages : 103
Prenom : LAURENT
fabrice 76 aime ce message
