-25%
749.99 € 999.99 €
Codes defaut des injections MPI
Codes defaut des injections MPI Empty Codes defaut des injections MPI
Message  TRISTANLCF Mer 21 Déc 2005 - 21:14
MPI Computer Codes
The MPI Kit is based on a 1994 Wrangler Multi Port Induction system.
How to get the codes:
1. Cycle the ignition key On - Off - On - Off - On within 5 seconds.
2. Count the number of times the check engine lamp on the dash flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual two digit trouble codes.
Example: Lamp flashes 5 times, pauses, and flashes 5 more times. This indicates a code number 55. A code 55 will always be the last code to be displayed. This will indicate the end of all stored codes.
Code / Probable cause
11 Ignition
12 Battery disconnected in last 50 cycles
13 Manifold Absolute Pressure (MAP) sensor vacuum
14 Manifold Absolute Pressure (MAP) sensor electrical
15 Speed sensor or circuit
17 Engine running too cool
21 Oxygen sensor or circuit
22 Coolant temperature sensor or circuit
23 Air charge temperature
24 Throttle Position Sensor (TPS) sensor or circuit
25 Automatic Idle Speed (Al S) control
27 Fuel injector control
33 Air conditioning clutch relay
34 Speed control solenoid driver
35 Fan control relay
41 Alternator field
42 Automatic shutdown relay
43 Ignition coil Number 1-3 primary circuit; peak primary circuit current isn’t reached with maximum dwell time
44 Battery temperature sensor
45 Overdrive solenoid - open or shorted condition detected in overdrive
46 Battery over voltage
47 Battery under voltage
51 Oxygen sensor - lean condition indicated
52 Additive adaptive memory at lean limit.
52 Oxygen sensor - rich condition indicated
53 Internal engine controller fault
54 Crankshaft signal sync pick-up signal - no fuel sync signal during crankshaft rotation
54 No cam sync signal at PCM; open or shorted condition in cam sync signal circuit
55 End of self-diagnostic display
62 Emissions Maintenance Reminder (EM R) mileage accumulator
63 Controller failure EEPROM write denied
76 Fuel pump resistor bypass relay
