-17%
249 € 299 €
Description technique Grand Wagonner et J- series
Description technique Grand Wagonner et J- series Empty Description technique Grand Wagonner et J- series
Message  Allmundi Ven 13 Avr 2007 - 11:29
Wagoneer, Grand Wagoneer, and J-Series Trucks
Description technique Grand Wagonner et J- series Gwagoneer
Description
Built from 1971 - 1991
All built on SJ platform
Models
Wagoneer, Grand Wagoneer (1971-1991)
J-10, j-20 Truck (1971-1987)
Cherokee (2 door and 4 door (1974-1983)
The Cherokee was introduced in 1974 as a lower cost alternative to the more luxurious Wagoneer
The Cherokee Chief variation offered wide track axles (65.5" instead of 59.2"). The Honcho was a truck but had the same wider axles.
Engines
AMC 258 cu in I-6 (1971-1987)
AMC 304 cu in V-8 (1971-1973)
AMC 360 cu in V-8 (1971-1991)
AMC 401 cu in V-8 (1974-1987)
Transmissions
Warner T-14A 3 speed manual (Wagoneer: I-6 1971-1979)
Warner T-15A 3 speed manual (Wagoneer and Trucks: V-8 1971-1979)
Warner T-18 4 speed manual (Wagoneer: 1971-1979, Trucks: 1971-1987)
Tremec T-176 4 speed manual (Wagoneer and Trucks: 1980-1986)
GM TH-400 3 Speed Automatic (Quadra-trac: 1971-1979)
Chrysler 727 3 speed automatic (Wagoneer: 1980-1991, Trucks: 1980-1987)
Transfer Cases
Dana 20 2-speed part time (1971-1979 manual)
Command-trac: NP 208 2-speed Part-time (1980-1991)
Selec-trac: NP 229 2-speed part-time/full-time (Optional 1983-1986)
Quadra-trac: NP 228 2-speed full-time (optional 1985-1991)
Selec-Trac: NP 242 2-speed part-time/full-time (optional 1987-1991)
quadra-trac: BW 1339 1-speed or 2-speed full-time (1971-1979 automatic)
Quadra-trac: NP 219 2-speed (optional 1980-1985)
rear Axle
dana 44 (Wagoneer and 1/2 ton truck: 1971-1975, wide tracks: 1974-1983, Grand wagoneer: 1987-1991)
amc 20 (Wagoneer and 1/2 ton truck: 1976-1986)
dana 60 (3/4 ton and 1 ton trucks: 1971-1987)
front axle
Dana 44
Allmundi
Allmundi
Nombre de messages : 3358
Prenom : Johann
