Description technique TJ
TJ wrangler (1997-present)
Description
Built since 1997 (there Was no 1996 wrangler)
round headlights again
first open jeep with air bags
93.4" wheelbase
in 2004 the wrangler "unlimited" was introduced (aka TJ-L) with a 10" longer wheelbase and 10" extra length behind the rear wheels. only a 4-speed automatic is offered.
more detail of late models is available at jeep.com
Engines
amc 151 cu in (2.5L) i-4 (1997-2003)
amc 4.0L (241 cu in) i-6 (1997-present)
daimlerchrysler 2.4L DOHC i-4 (2004-present)
Transmissions
ax-15 5 speed manual
chrysler 32RH 3-speed automatic (1997-2003)
daimlerchrysler 4-speed automatic (2004-present)
Transfer Cases
nv-231j 2-speed (aka command-trac)
rear Axle
Dana 35
dana 44 (optional, some models)
dana m35 (some newer models)
front axle
dana 30
dana m44 (rubicon model)
Description
93.4" wheelbase
Engines
Transmissions
Transfer Cases
rear Axle
Dana 35
front axle
dana 30
- Nombre de messages : 3358
Prenom : Johann
» Description technique ZJ
» Description technique WJ
» Description technique CJ8
» Description technique YJ
» Description technique KJ
