Description technique CJ2A et M38
willys cj-2a & m38
Description
Built from 1946 to 1949
cj2a was the first civilian jeep
m38 was the military equivalent
flat fenders
80" Wheel base
25" tall split windshield with top mounted wipers
side mounted spare tire
hood height of 6"
5"x5.5" bolt pattern on wheels
Engine
L-head 134 Inline 4 cylynder engine
Transmission
T-90 3 Speed manual (early models used a T-90 column shift)
Transfer Case
Dana 18 2-speed transfer case
Axles
Dana 23-2 rear(early models), dana 41 or 44 rear (later models), Dana 25 front
Serial Numbers
1945 - 10001-11824
1946 - 11825-83379
1947 - 83380-148458
1948 - 148459-222581
1949 - 222582-224764
Description
flat fenders
80" Wheel base
hood height of 6"
Engine
Transmission
Transfer Case
Axles
Serial Numbers
1945 - 10001-11824
1946 - 11825-83379
1947 - 83380-148458
- Nombre de messages : 3358
Prenom : Johann
» Description technique CJ5
» Description technique XJ
» Description technique ZJ
» Description technique WJ
» Description technique CJ8
