599 €
Description technique ZJ
Description technique ZJ Empty Description technique ZJ
Message  Allmundi Ven 13 Avr 2007 - 11:07
ZJ Grand Cherokee (1993-1998)
Description technique ZJ ZJ
Description
The ZJ was originally designed in the 80s by AMC to replace the XJ cherokee. When amc hit financial trouble and was purchased by chrysler in the late 80s the zj plans were put on hold.
Introduced 4 wheel coil spring suspension with front and rear solid axles
105.9" wheelbase
Engines
241 Cu in/4.0L I-6
318 cu in/5.2L V-8
360 cu in/5.9L v-8 (Rare Option in 1998 limited models)
Transmissions
AW30-40 4-speed automatic (early 1993)
42RE 4 speed automatic (I-6: 1993-1998)
46RH 4 speed automatic (v-8: 1993-1995)
44re 4 speed automatic (5.2L v-8: 1996-1998)
46RE 4 speed automatic (5.9L v-8: 1998)
Transfer Cases
Command-trac: NV 231J Part-time (1993-1995)
Selec-trac: NV 242 Part-time/full-time (1993-1998)
Quadra-trac: NV 249 Full-time (standard on V-8s, optional on I-6: 1996-1998)
rear Axle
Dana 44
front axle
Dana 30
dana 44 (optional)
Allmundi
Allmundi
Nombre de messages : 3358
Prenom : Johann
